Definitely invest in a wiring harness if at all possible, if you haven't already done so. For less than $12-$15, saves you a lot of headaches down the road from splicing into the existing harness. That way, you retain the durability of the OEM harness, and just chop up the cheap harness.
Down the road you might want to upgrade the headunit - with a harness, just unplug, chop off old headunit connectors, replace with new headunit wiring, plug back to OEM wiring connections - good to go.
