Which model year Corolla do you have?
1998-1999 have plug wires but no cap and rotor. 2000+ are all coil on plugs (no cap, no rotor, no wires).
Sounds like you have a 7th gen 1993-1997 or older generation of Corolla - since you mentioned cap and rotor. If you haven't already checked the plugs - do so. Hard starting / rough starting can be caused by a number of culprits. From bad gas, to excessively viscous motor oil, bad injectors, bad coil pack, worn cap/rotor, damaged plug wires, worn sparkplugs, or just a sign of needed a general tuneup.
