Oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2011, 11:48 AM   #1 (permalink)
View captaincorolla's Photo Gallery
Oil
How much oil (approx) does the 2000 Corolla have/need in it?
2000 Silver Corolla LE
Carbon fiber altezzas, reverse indiglo gauges, blue LED interior/swapout, clear corners, xenon headlights/corners, MP3 deck, alarm w/ battery backup & pain generator, mesh grill and repainted exterior.
captaincorolla is offline   Reply With Quote
Old 03-31-2011, 12:00 PM   #2 (permalink)
Mileage King
View COYOTE556's Photo Gallery
Mine has a 1.8L and I always put in 4qts.
COYOTE556 is offline   Reply With Quote
Old 03-31-2011, 12:26 PM   #3 (permalink)
View 1998rolla's Photo Gallery
1.8 L takes 4 quarts
1998rolla is offline   Reply With Quote
Old 03-31-2011, 08:22 PM   #4 (permalink)
Bdub215's Avatar
Gameroom cash: $317265
View Bdub215's Photo Gallery
I usually put 4.5 quarts in my car. 4 quarts leaves it low.
Sent from my iPhone using Autoguide
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 04-01-2011, 09:24 AM   #5 (permalink)
View tetrisken's Photo Gallery
3.7 quarts without the oil filter replacement. 3.9 with the filter replacement. If you have had an updated dipstick installed, it could be 4.5. You should be able to check the driver's side door for details.
tetrisken is offline   Reply With Quote
Old 04-04-2011, 12:16 PM   #6 (permalink)
Thanks, just needed an estimate. I wanted to dump some Sea Foam in the crank case before my oil change. Both are now done.
Old 04-05-2011, 06:44 PM   #7 (permalink)
Corolla Owner
leeor_net's Avatar
View leeor_net's Photo Gallery
4 quarts is too much unless you're not filling your oil filter before you install it. And even then, you should be checking your oil level as you get near the end to ensure you don't over fill.
The actual spec is 3.9 quarts for a complete change with oil filter. But, don't take that as the final word -- check the level as you fill so you don't over fill. Over filling can be just as bad as underfilling.
- Leeor
leeor_net is offline   Reply With Quote
Old 04-07-2011, 04:43 PM   #8 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
Book shows 3.9 quarts with filter. I always throw in 4 and havent had a problem in 100k miles.
I dont think that .1 quart could hurt the engine other than some fluke thing. Noa a half a quart might cause problems. (if its not burnt off)
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 04-08-2011, 12:26 AM   #9 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
Like what was mentioned above ,there is an updated dip stick that requires more oil to reach its full line. An attempt at a partial fix for the oil sludge problem.
sam333 is offline   Reply With Quote
