Engine Check Light: P0301 - Cylinder 1 Misfire
Hi Guys,
So the unfortunate happened. I saw the engine check light and after i pulled the code, it was P0301 which meant "cylinder 1 misfire".
now the preface, the night before the car was running perfectly fine. nothing unusual from the daily drive, sounds of the car were perfectly fine. nothing deviated from the norm. i parked it on the driveway and went inside for the night.
on saturday morning (it was windy, cold, and raining) i went out to start the car. now it normally jumps to ~2000 RPM and then as the car warms up, it slowly drops to ~1000 RPM.
it did not do this on saturday morning. it went to ~1100 RPM and stayed there at idle. this is out of the norm. i went back inside and when i came back out the engine light was on.
after pulling the code, "cylinder 1 misfire". what do you guys think could have caused this overnight? the only thing that changed was the weather.
i changed the spark plugs several months ago. the spark plug wires are OEM (98 corolla, 186,000 KM). everything "ignition" wise is OEM. someone said to me that it maybe the spark plug wires b/c they're old and the insulation may be bad. combined with the wet and cold weather from saturday morning, this may have shorted it out. although i didn't see any visible sparks from the wires itself.
so, what do you guys think is the problem and what should i try first to resolve it? i am planning to change out the 4 spark plug wires first.
another question to clarifiy as i've been hearing different answers. does the 98 corolla have ignition coil or distributor or coil on plug (COP)? i'm VERY confused with regards to this.
thank you for the help guys.
