You can buy the rear quickstruts yourself for around $180 - 210 ea side, so the shop is charging you roughly $200 labor.
Two ways to do it:
1. Buy the Quickstruts and save a bunch on labor, quickstruts are the complete assembly including spring, bearing plate, etc. and is much faster and simpler to install.
2. Buy just the strut, and have to remove the spring, bushings, etc. from the old assembly. Cheaper in parts but lots more labor.
Six hundred including checking the wheel alignment probably isn't too bad. You could buy the struts you linked and do it yourself, there are how-to guides online you can follow. You'll need to rent a spring compressor, but if you buy the struts from a local parts store they'll loan it to you for free.
And if you're very careful to get the new ones on in the same place you might get by without aligning the wheels.
I only know this because I need new rear struts on my 00 Rolla, and I've been doing a lot of research on it. The service manager and lead wrench where I get all my work done have been very helpful, and I'll probably end up buying the cheapest quickstruts I can find on sale and paying them the 200 or so to put them on.
