Inside FAN is very LOUD !! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2011, 09:30 AM   #1 (permalink)
00 Corolla - VVTi
View Balik's Photo Gallery
My inside fan that works with all the heating and cooling makes loud noise at medium and higher setting. Higher the setting louder it is.
Any suggestion on what could the cause and what needs to be fixed ?
00 Corolla VVTi at 90K miles
Thanks
Balik is offline   Reply With Quote
Old 04-25-2011, 10:34 AM   #2 (permalink)
pdq
Gameroom cash: $221400
View pdq's Photo Gallery
Are any of your vents closed? If mine are closed all the way I get a high-pitched whine.
pdq is online now   Reply With Quote
Old 04-25-2011, 10:42 AM   #3 (permalink)
00 Corolla - VVTi
It doesn't looks like it.
however If I select Circulate Inside air option, sound increase 3 times.
Loud Fan Sound is coming from Passenger side foot well, always.
Old 04-25-2011, 10:47 AM   #4 (permalink)
pdq
If the sound is only loud on re-circulate mode, the return air vent is probably clogged with trash or debris. Check underneath the passenger seat for the plastic return vent and you might need a coat-hanger or similar to clean it out.
Old 04-25-2011, 09:14 PM   #5 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
Your fan might need to be replaced. Setting the circulation to inside air mode, opens the door to the interior, so the sound comes straight into the car, so it sounds louder.
gold94corolla is offline   Reply With Quote
Old 04-26-2011, 08:50 AM   #6 (permalink)
00 Corolla - VVTi
Is there a schematic diagram available , showing where and what part should I check for this noise inside the car ?
Old 04-26-2011, 08:59 AM   #7 (permalink)
00 Corolla - VVTi
Is replacing this fan expensive ?
Old 04-26-2011, 04:26 PM   #8 (permalink)
shouldn't be.... just remove the glovebox and it is right behind there. Check it out, and you can probably find another one in a junkyard or Ebay.
Old 04-26-2011, 09:30 PM   #9 (permalink)
View militarydave's Photo Gallery
mine whistles when the vents are closed too!
militarydave is offline   Reply With Quote
Old 04-26-2011, 09:36 PM   #10 (permalink)
well, the vents themselves will whistle when closed if the sealing foam stuff is missing from the door shutter.
