power window switch? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2011, 04:15 PM   #1 (permalink)
View jtaka's Photo Gallery
I have a 2000 corolla with a power window dilema. The window on the driver side will go down. But only got up slowly or stop all together.The window will go up with help by pushing on the outside of the glass.
1 I have taken the switch out and sprayed with a cleaner with no change.
2 The driver switch seems to have a lot of play versus the other switches.
3 I have checked all the connections and also there does not seem to be any shorts in the wiring.
With all that being said does this sound like the switch? Is there a way to test the switch? Could it be something else? I am trying to eliminate one thing at a time. Any help or suggestions would be appreciated
Jerrry
jtaka is offline   Reply With Quote
Old 04-27-2011, 04:44 PM   #2 (permalink)
pdq
Gameroom cash: $221400
View pdq's Photo Gallery
You almost surely need to replace the window regulator motor. You can get them at junkyards or ebay.
pdq is online now   Reply With Quote
Old 04-27-2011, 10:13 PM   #3 (permalink)
View 1.8litrebeater's Photo Gallery
The switch does not control speed, if it were bad the window would not go up at all. Try spraying wd40 or silicone lubricant into the windows channels and see if that helps. If no then most likely pdq is right.
98 Corolla CE
1.8litrebeater is offline   Reply With Quote
Old 04-28-2011, 12:14 AM   #4 (permalink)
Thanks for the info on my window problem. I will try the wd40 trick. I used that on my honda when the windows would get stuck. Also if I have to change the window regulator is there info on tips to do this swap? Thanks again for all the info.
Jerry
Old 04-28-2011, 01:39 PM   #5 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Try cleaning the upper and lower channels rubber insert, they get a lot of dirt buildup. And make sure the rubber inserts are in place in the channels and not mis-formed.
For lube I would go with white grease, Maybe try some on the regulator as well.
CraigW is offline   Reply With Quote
Old 04-28-2011, 04:26 PM   #6 (permalink)
Great info. I am thinking can i just replace the motor and not the entire actuator? It dosnt look that bad and how would i know if its the actuator and not the motor?
Jerry
Old 04-29-2011, 03:12 PM   #7 (permalink)
I read another post about it might be the actuator may need to be greased more. I think I will try that first. Also is there a step by step method to just replace the motor and not the actuator.
thanks
jerry
Old 04-29-2011, 07:19 PM   #8 (permalink)
View Kyle Hamelin's Photo Gallery
Check out this link on how to replace the motor.
http://rinconrolla98.blogspot.com/20...lla-98-02.html
You can thank leeor_net a member on here for that one.
Also here is a link to another thread about this topic.
Driver Window Question -
Kyle Hamelin is offline   Reply With Quote
Old 04-30-2011, 08:01 AM   #9 (permalink)
pdq
Actually that tutorial is from the user RinconRolla98.
There's a chance you just need to grease the tracks (ie it's filled with dirt and sticky), but since it goes down okay, my bet would be the motor is almost burned out.
Old 04-30-2011, 11:48 PM   #10 (permalink)
I am going to take off panel tomorrow. can i grease the rail without taking things apart?
Jerry
