which engine is btter 98-99 or 2000-2002? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2011, 07:32 PM   #1 (permalink)
View yoshiki2's Photo Gallery
what engine is the one that doesn't burn any oil? or both of them do it?
yoshiki2 is offline   Reply With Quote
Old 04-27-2011, 07:39 PM   #2 (permalink)
Gameroom cash: $116900
View Clayton1984's Photo Gallery
All 8th gen Toyota engines burn oil.
The problem was substantially reduced in 2003+
Clayton1984 is offline   Reply With Quote
Old 04-27-2011, 07:43 PM   #3 (permalink)
Toy-rollin
View Blaam's Photo Gallery
the 1zz-fe engine released in the us in 98 was in all 8th gen corollas. as far as oil burning i would take a look at each individual vehicle as they all have the same engine. the oil burning condition is a problem with high-milage engines in which is called 'blow-by'. blow by is when oil under pressure gets bast the piston rings into the combustion chamber....not the easiest repair i might add.
my recommendation is to find a corolla, 8th or 9th gen with less then 200k miles.
Got Trophies?
Blaam is offline   Reply With Quote
Old 04-28-2011, 08:55 AM   #4 (permalink)
View Kyle Hamelin's Photo Gallery
This is incorrect as I have a 2001 LE model that drops only 2-3cm on the dip stick after 5000km+ of driving on it. Also my car has 200,000KM on it.
Kyle Hamelin is offline   Reply With Quote
Old 04-28-2011, 09:25 AM   #5 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
Well my 2001 le never burns oil at all...well its actually at 100700 miles, is that high or low???
ilovecorollale is offline   Reply With Quote
Old 04-28-2011, 10:45 AM   #6 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
They all( 98-2002) have the potential to burn oil because of the poor piston design. I have not heard of one person running synthetic oil that has major oil burning problems though.
sam333 is offline   Reply With Quote
Old 04-28-2011, 10:53 AM   #7 (permalink)
This is true. I always put full synthetic castrol oil in mine.
Old 04-28-2011, 10:18 PM   #8 (permalink)
on full afterburner
Gameroom cash: $1346497
Assuming that you take care of your car, that's barely broken in.
Old 04-29-2011, 02:04 AM   #9 (permalink)
View Highway_maniac's Photo Gallery
As far I know, the problem of oil burning has 2 causes:
- wrong materials used fot the oil scrape rings.
- oil channels in piston insufficient.
The first problem was solved in 2001 as far I know. The oil burning problem was not fully solved, Toyota re-designed the piston, doubling the oil channels (from 4 to 8). Also heard they enlarged the oil holes. This was done in 2003 as far I know.
There is a TSB for the oil burning, also describing the cause of the problem.
Highway_maniac is offline   Reply With Quote
Old 04-29-2011, 11:51 AM   #10 (permalink)
Do you have a link to the info about the rings being the wrong material?
The holes were doubled in number( 4 to 8) and in diameter( 4x the area)also the holes were repositioned from entirely in the ring grove to half in the ring grove and half below (for better oil drainage/flow).
The only pistons toyota sells now are the revised ones , but they only sell them in standard sizes, so if you need a rebore, then you will have to go with an aftermarket brand. From what I have seen most of the affordable aftermarket pistons for this engine have the original small four hole design ( Nippon
Piston Ring sets about a $100). You can always go with high end forged aftermarket pistons( about $500 a set).
Old 04-29-2011, 07:33 PM   #11 (permalink)
115k miles
01loadedLE's Avatar
Gameroom cash: $123100
View 01loadedLE's Photo Gallery
[the oil burning condition is a problem with high-milage engines]
My car was burning oil from the start when it was new. I was shocked to find the oil halfway between the Full and Add dipstick marks after a month of driving around 1200 miles.
I'd rather be flying.
Pics & info on my 01 LE
01loadedLE is offline   Reply With Quote
Old 05-02-2011, 07:10 PM   #12 (permalink)
View militarydave's Photo Gallery
I have a 1999 CE with the 4spd auto with approx. 171,278 miles on it. the old lady (1 owner) took it to toyota every time for EVERYTHING. I mean EVERYTHING. light bulb? dealer. wiper blades? dealer.
Got the car for $1500.
She was using 5W-20 (well the dealer was) conventional (snake/dino oil).
I switched it to 10W-40 - High Mileage.
I'm pretty damn sure if i put FULL SYNTHETIC (such as Royal Purple or Mobil 1) i'll get an oil leak, as those seals are accustomed to the snake/dino oil.
thus far, i'm getting 34-36 MPG with A/C on half way doing a consistant 80-85 MPG for a straight 26 mile tollway.
i also drive the complete batshit out of it. i got it with 167xxx on the clock.
militarydave is offline   Reply With Quote
Old 05-02-2011, 07:11 PM   #13 (permalink)
oh yeah.. doesnt burn a tear drop of oil.
Old 05-04-2011, 02:15 AM   #14 (permalink)
There is a service bullitin Toyota, don't know the numer. But check this out:
https://docs.google.com/fileview?id=...NjBiMDYx&hl=en
It has lots of information about the problem. 1ZZ-FE engine is named in the document.
