Need Advice: Kickdown Cable, 2000 Corolla LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2011, 04:42 PM   #1 (permalink)
View J.R.Freeman's Photo Gallery
Hi all,
The kick-down cable on my girlfriend's Corolla is seized, and has been disabled. Is the cable difficult to remove from the transmission? Will I need to remove the pan from the bottom of the transmission to access the lever the cable is attached to?
Thanks,
Jim Freeman
J.R.Freeman is offline   Reply With Quote
Old 05-11-2011, 07:49 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
Throttle side should be easy. Just pull and you should be able to unhook it. The other end you will need to drop the pan to unhook.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 05-11-2011, 08:06 PM   #3 (permalink)
Hi Buurin,
Thanks for your response. Ok that sounds good. You're right - I had the throttle end off without trouble, but I wasn't sure how to get the other end undone. I'll drop the pan once my new cable comes in.
Thanks again!
Jim
