Rattling coming from engine, power steering pump? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2011, 07:46 AM   #1 (permalink)
View brooklyn99corolla's Photo Gallery
I have rattling coming from the engine, sounds like its coming from the pullys. Does not rattle when engine is cold, what i noticed, when turning the steering wheel (left or right, driving or still) the rattling stops! is there a changable pully on the steering pump or could it be something else? Thanks
1999 Toyota Corolla CE
2005 Tahoe Z71 - 22" Liquid Metals-Western Ultimate
Bull W/PIAA 520-OEM NavW/6 Disc Changer - Every Available Option
2007 Infiniti QX56 - 22" Konig Rolf Blix - Every Available Option
brooklyn99corolla is offline   Reply With Quote
Old 05-17-2011, 09:24 AM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Could be a number of things causing a rattling noise on the pulley side. The noise going away when you turn the steering wheel is likely NOT a problem with the power steering system, as turning it is loading the belt. Power steering pump issues manifest more as a whirring noise (sounds like a supercharger) than a rattling noise. Though it probably is a good idea to double check all the pulley bolts to make sure they haven't worked loose.
More than likely, this noise could indicate a loose belt, worn belt, bad belt tensioner (common), bad idler pulley, or bad pulley on one of the accessories (A/C, alternator, P/S pump).
Old 05-18-2011, 02:21 AM   #3 (permalink)
View gbell210's Photo Gallery
To narrow it down to a pulley/tensioner, you can pull the belt off and run it for just a bit. I just tracked down my rattle to the belt tensioner shock. I narrowed that down by putting some pressure on the belt tensioner and it went away. Then removed the belt to make sure.
Also, mine only rattled at idle after warming up. The idle was too high when cold. I didn't have a good wrench to get the whole tensioner arm off, so I just swapped the shock. No more rattle for me. To bad that shock isn't sold seperately (i don't think it is at least). The whole arm at Napa was $110. So I still have a brand new arm minus a shock.
'01 Corolla LE (The gas Miser)
'89 Supra Turbo (Blitz Nur Spec, Michellin Pilot Sports)
'94 Land Cruiser (ARB front, Kaymar rear, sliders, lifted and locked)
gbell210 is offline   Reply With Quote
Old 05-18-2011, 01:31 PM   #4 (permalink)
View Corolla Payolla's Photo Gallery
Are you sure it's not the sway bar end links!
Corolla Payolla is offline   Reply With Quote
