Sometimes it is helpful to disconnect the battery after these sort of cleanings, as it will force the ECM to re-learn new parameters. Not a bad thing, if the MAF sensor was excessively dirty to start with. The ECM will re-learn new parameters without being cleared, but I find the car always seems to run better, re-learn faster if you start with a blank slate, so to speak.
