Really need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2011, 05:10 PM   #1 (permalink)
View Thomas37664's Photo Gallery
Angry Really need help
Ok im new here.....enough bs. Heres the symptoms with thee enine running. I turn on the turn signals..the car dies. use the hazards it dies. I dont have any head lights. If you unplug the hazards then it runs fine but you lose your signals. The signals blink fast like I have a blown buble. I dont. The relay does buzz a little. Changed it out, nothing changed. Now the fuel injectors are firing. Im not trying to start the car. The key is on. Im stumped ive been trying to find this gremlin for 3 days PLEASE HELP
Thomas37664 is offline   Reply With Quote
Old 05-26-2011, 05:59 PM   #2 (permalink)
pdq
Gameroom cash: $221400
View pdq's Photo Gallery
Have you checked the battery voltage while the car is off and while the key is in the ACC/ON position? Sounds like a bad battery, electrical short or fuse problem, or alternator problem.
pdq is online now   Reply With Quote
Old 05-26-2011, 06:04 PM   #3 (permalink)
Angry
The battery is 12.86 volts. The alt. Is good. Im stumped. The dash is all apart ive been tracing wires sinse about 1:30 pm today. So far no open loops or big change in voltage.
Old 05-26-2011, 08:15 PM   #4 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
What year/model/make is your car?
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 05-26-2011, 08:18 PM   #5 (permalink)
Its a 1999 Corolla ce. Automatics trans
Old 05-27-2011, 03:13 PM   #6 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
Start from the battery and work down.
Dont just look at connections, remove the wires, fuses where you can and clean.
You wont always be able to see the corrosion.
The best way to find areas of high resistace( which is probably what you have ) is to start the car , put a load on the electrical system( turn on headlights or blower ect.) the set your multimeter ( to volts , low setting if you dont have autorange) and start testing across power( positive to positive) and ground( negative to negative )connections.
Anything over 0.2 votls is suspect and anything over .04 volts is a definate problem.
Before you start these tests, its a given that you have allready tested your battery and alternator under load.
This is a super common problem.
sam333 is offline   Reply With Quote
