If there is a hole in the boot/bellows on the piston, it's only a matter of time until the caliper seizes up on you. A reman. caliper would be your best bet, it is possible to put new seals in a caliper (if you can find a kit), but it's a little tricky to do, and I suspect you are a novice based on asking this question. Not to put you down by any means, just trying to help you not bite off more than you can / want to chew, and since brakes are somewhat related to safety, swapping in a reman caliper and bleeding it would be much more straightforward.
"The thing about quotes on the Internet is you can't confirm their validity"
Abraham Lincoln
