'98 Mysterious Oil Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2011, 07:41 PM   #1 (permalink)
ScienceOfThePS3's Avatar
View ScienceOfThePS3's Photo Gallery
Hello,
I just got the oil changed on my 98 Corolla two days ago, however I've noticed it leaking a bit oil a couple hours after and just today after letting it sit yesterday. It's not a catastrophic leak, but enough to get me concerned, especially since this just started happening right after I get my oil changed.
I went under the car and checked the screw (which was tight), oil filter (which was also tight), and even oil pan itself for leaks but came up dry as a bone. It's definitely not coming from the top of the engine, but it seems like it's coming from the passenger side about a foot away from the wheel. A friend was saying that it may be the "engine seal" if that makes any sense? The engine's got over 250k on it, but it's still surprising that it's leaking oil all of a sudden, even with it's age.
Thanks!
ScienceOfThePS3 is offline   Reply With Quote
Old 05-30-2011, 11:53 PM   #2 (permalink)
View 2damaxsupra's Photo Gallery
I am pretty sure it is the tensioner o-ring.
1998 Toyota Corolla ve 5spd
400,000+ km and counting!
2damaxsupra is offline   Reply With Quote
Old 05-31-2011, 08:16 AM   #3 (permalink)
View dorman68's Photo Gallery
X2 on the tensioner o-ring, fairly common issue when the 1zzfe's accumulate mileage.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 05-31-2011, 12:01 PM   #4 (permalink)
Just checked and I see no signs of leaking from the timing chain tensioner, at least from what I could see above. I might need to get the car on a lift and look under it.
Old 06-17-2011, 10:16 PM   #5 (permalink)
View ScoopDL's Photo Gallery
USA Tensioner O-Ring
Change my valve cover gasket cause I had oil all over the pully side of the engine - then realized that everyone on here was right - source was the tensioner o-ring. $20 at O'Reilly and 20 minutes of work and now no more leak. What really got me was the dealer told me a year ago I had a head gasket leaking but I knew it was BS.
ScoopDL is offline   Reply With Quote
Old 06-18-2011, 11:31 AM   #6 (permalink)
115k miles
01loadedLE's Avatar
Gameroom cash: $123100
View 01loadedLE's Photo Gallery
A can of AT205 Resealer worked for me. I had several seal leaks.
I'd rather be flying.
Pics & info on my 01 LE
01loadedLE is offline   Reply With Quote
Old 06-19-2011, 12:36 AM   #7 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
Who ever changed your oil could have spilled some , wash down the engine , run it and look for leaks again.
sam333 is offline   Reply With Quote
