01 Corolla - Replace Front Turn / Corner Signal Housing? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2011, 09:35 PM   #1 (permalink)
View SaturnX's Photo Gallery
Question 01 Corolla - Replace Front Turn / Corner Signal Housing?
Hey all!
Long time lurker, first time poster!
Just got word from the gf that the lens on her driver's side turn/corner signal lamp has popped clean off.
Looks like the adhesive completely dried out and the lens popped off cleanly. Unfortunately the lens is MIA so looks like I'll be replacing the entire housing.
Before I dive in, is the corner signal housing only held in by the one (1) retaining screw? or do I need to take the bumper off or something else?
Thanks for all the help!
Cheers!
Snapshot of the Lamp
SaturnX is offline   Reply With Quote
Old 06-02-2011, 12:03 AM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
Easy. One screw then it's straight pull towards the front. Pull the plug. Put in new corner, reverse the process.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 06-02-2011, 03:43 PM   #3 (permalink)
View pchalpin's Photo Gallery
It's a straight out pull after the screw is removed. BUT, there are two plastic fingers that slide in to the outside and top of the fender. Of course they both have little protrusions at the end that catch on the fender to keep the housing from sliding out. Use a long thin flat screwdriver to unlatch the protrusions, then the housing will slide out. I filed off the protrusions when I put the housing back in so that the next time I need to remove it I won't have to overcome another shitty Toyota design.
pchalpin is offline   Reply With Quote
Old 06-02-2011, 09:02 PM   #4 (permalink)
Perfect! Thanks for all the tips, sounds like this should be a breeze!
One more follow up question, I was looking to pick up a new housing on eBay which has some decent prices, but when the gf called the dealer they mentioned that there was a "newer" and "older" turn signal lamp housing.
Was there a facelift or tweak to the headlights/signal lights during the production of the 8th gen corollas?
Thank again!
Old 06-02-2011, 09:13 PM   #5 (permalink)
Mad Microbiologist
RoachRolla's Avatar
View RoachRolla's Photo Gallery
98-00 have the tear drop headlights. 01-02 have the extra round part for the high beams. apparently the corners fit differently as well. my box of corners says 01-02 corners
RollaRoyce
'02 Corolla
Injen SRI, Magnaflow catback, lip kit, Tein S-Tech, Konig BriteLites, Prestige security, and Mila Kunis in the passenger seat !
26,6xx miles!
http://www.cardomain.com/ride/3842039
RoachRolla is offline   Reply With Quote
Old 06-02-2011, 11:16 PM   #6 (permalink)
Beware of pigs
Buurin's Avatar
01-02 corners are taller to the bottom and has a curved edge on the side adjacent to the headlight, to accommodate the larger low beam.
Buy my parts
Buy my other stuff
