The Case of The Lost Ground Wire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2011, 12:09 PM   #1 (permalink)
Gameroom cash: $198200
View gregzbutt's Photo Gallery
While replacing the spark plugs yesterday I found a free roaming ground wire without a home. I was hoping someone could check their car and help me find a comfortable place for it. It's the very first wire that splits off the ground cable as you follow it from the negative side of the battery. There's a black plastic connector that attaches it to the battery ground.
Thanks,
Greg
gregzbutt is offline   Reply With Quote
Old 06-03-2011, 12:36 PM   #2 (permalink)
View bail_w's Photo Gallery
Post a picture would be great.
bail_w is offline   Reply With Quote
Old 06-03-2011, 03:59 PM   #3 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
That wire is your main body ground ( the other heavier wire goes to the trans). It goes right under and between the main fuse block and air cleaner. You will have to remove your air cleaner to reattach it .
sam333 is offline   Reply With Quote
