engine hit 90k and now engine noise :( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2011, 12:26 AM   #1 (permalink)
View HAWAZNPERSUAZN's Photo Gallery
http://s1099.photobucket.com/albums/...6-06at1847.mp4
HAWAZNPERSUAZN is offline   Reply With Quote
Old 06-07-2011, 01:19 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Noise seems to follow engine speed (vibration speeds up when you raise engine RPMs) - could be a number of things - doesn't sound like one of those "fatal" engine sounds.
More like the exhaust heat shield touching the exhaust manifold and vibrating. Could also be a bad belt tensioner as well - you could try running the engine with the serpentine belt off for a short time to see if it is related to the belt, will not hurt the engine if run for a very short time - enough time to diagnose the noise.
Since you can hear it from the bottom of the car and out the side by the wheel well - my money is on a loose heat shield or broken/loose exhaust bracket/clamp/blow out exhaust gasket.
Assuming you checked all the simple stuff - make sure fluids are in good shape, plenty of fresh engine oil, car didn't experience any overheating or accident before this noise started up.
Old 06-08-2011, 02:05 AM   #3 (permalink)
no accidents happened before this.. all fluids checked out find. oil change 200 miles ago. no lost in power all belts changed at 80k miles thanks for helping
