First double check that the momentary door switches are working correctly. Push the plunger in and see if it moves smoothly. Check for any tears in the rubber cover, see if it is binding up on you.
You can test the switch by removing it from the chassis and disconnecting the electrical connection on the end (make sure to disconnect the battery for any electrical work). Check for continuity between the switch body and the pin on the bottom when the plunger is not pushed in and no continuity when the plunger is depressed.
