acceleration problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2011, 07:24 PM   #1 (permalink)
View dadi's Photo Gallery
Canada acceleration problem
hi i need help for my rolla 98 sometimes it don't want pick-up also last time when i change the motor oil i found not even one litter no leak ??
thanks
dadi is offline   Reply With Quote
Old 06-17-2011, 09:49 PM   #2 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
Your burning oil , check your plugs for deposits( check oil at every gas up or you will burn up your engine) , Do a tune up ( clean MAF new plugs , air filter).
sam333 is offline   Reply With Quote
Old 06-17-2011, 10:10 PM   #3 (permalink)
Gameroom cash: $196050
View landphil's Photo Gallery
Start with a compression test before you spend any money tuning it up - running with <1L oil =
"The thing about quotes on the Internet is you can't confirm their validity"
Abraham Lincoln
landphil is offline   Reply With Quote
Old 06-18-2011, 09:56 AM   #4 (permalink)
hi thanks for replay
i check it this morning and i found oil around spark plug
is it easy to change the seals ? and what key size do i need to do it?
thanks
Old 06-20-2011, 05:41 PM   #5 (permalink)
View 2damaxsupra's Photo Gallery
Define "around" spark plug. Is oil found on the thread or on the electrode?
1998 Toyota Corolla ve 5spd
400,000+ km and counting!
2damaxsupra is offline   Reply With Quote
Old 06-20-2011, 06:05 PM   #6 (permalink)
pdq
Gameroom cash: $221400
View pdq's Photo Gallery
dadi, it's a pretty easy job (less than 1 hour). Buy a valve cover gasket and some black RTV silicone sealant.
Here's a great pictorial:
http://www.peakreflections.com/uploa...eplacement.pdf
pdq is online now   Reply With Quote
Old 06-20-2011, 06:41 PM   #7 (permalink)
hi thanks
i order the cover gasket and will install it
your PDF file will help thanks to much and thanks for every body
