Originally Posted by fishexpo101
^^^ Did you pull the plugs to see if you still got fuel (plugs are wet)?
As for coils - you can use a ohmmeter to check the coils - the typical range of valves are listed on this forum, as someone already posted about something like that some time ago.
Same with the plug wires - check them with an ohmmeter to see if any are open - also a good time to check them for physical damage (chewed up insulation, bare spots, etc.)
Having to push in the gas a bit to get it to start does sound a bit odd. Might not be an ignition issue - could be fuel related, either a gummed up throttlebody or clogged or dying fuel pump.
When I pulled the plugs they were coated with oil, not burned on oil fresh oil. The only time the car would smoke was when it was revved hard (say 4700 + rpm's). I cleaned them with laquer thinner.
The batteries are dead in my tester so i couldnt test the plugs or wires.
I pulled one plug wire at a time and put it against the valve cover while cranking, it is getting fire, the spark isnt blue.... it mostly whitish/yellow sometimes orange.
I pulled the quick disconnect line on the fuel and turned the ignition on, I am not getting any fuel.
I am hoping this is a relay (if it has one for the fuel pump) and not the fuel pump its self. Chances are its the fuel pump cause the car has 182,xxx miles on it.
If anyone knows if the 98 corolla has a fuel pump relay, could you inform me of where its located. or better yet a link to an online shop repair manual for the 98 corolla.
