Can I just add for the future, Ray, (although you didn't over-tighten the filter you had to deal with, it was someone else):
When putting on new filter do it this way:
hand tighten only, until filter just makes contact with engine (Be SURE you got the old gasket off first).
Note what marking on the filter is at a particular point (say twelve o'clock). Then turn filter just 1/2 to at most 3/4 turn more. so that marking (you can make one with a permanent marker if you wish) should now have moved 180 to 270 degrees clock-wise, No More! You really don't need to reef on these.
Be sure to dab some clean oil on the new filter gasket & threads first, BTW.
I did a DIY FAQ with pics on doing an oil change in the 2001 HL section; I know not same vehicle, but the basic ideas are the same. Maybe it will help.
DIY Oil Change ... anyone has a tutorial with pics?
Glad you got it done! Now takes some pics & write your own DIY!
Geoff
