A/C Problems!? Had A/C serviced. Again, no cold air! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2011, 04:54 PM   #1 (permalink)
View timkedz's Photo Gallery
Hello,
I am having a lot of trouble with my 2000 Toyota Corolla's A/C system.
First of all, on the first hot day this year, I tried to start my A/C and found it pumped out hot air. No compressor engagement at all. I checked the fuses and relays and found them all to be okay. Serpentine belt was fine as well.
Took it to the garage and lo and behold, it was low on refrigerant. It wasn't empty, but low.
I had it vacuum checked and no obvious leaks were found.
Then, all the old refrigerant was sucked out and it was refilled with R134a with dye and double checked for leaks. Apparently none were found.
A/C was icy cold.
However;
About a week later, I turned on my A/C on an 80 degree day and again, no cold air!!
I opened the hood and found the compressor to be running, but, absolutely no cold air at all.
I checked the temerature lever to make sure that I didn't leave it on the hot setting.
I noticed that car's rpms don't change very much when I engage the A/C clutch. Again, it spins, but, doesn't seem to be doing anything.
Any help or information would be greatly appreciated!
Thanks!
timkedz is offline   Reply With Quote
Old 06-27-2011, 09:10 AM   #2 (permalink)
pdq
Gameroom cash: $221400
View pdq's Photo Gallery
You have a refrigerant leak in your system and need to find/fix that first. The usual suspects are either a schrader valve or the compressor itself. It's a large leak if it's warm within a few weeks of charging the system.
You probably need to go to a mechanic who can inject dye into the system and then see leaks visually with colored glasses and a blacklight. If it's just a schrader valve, those are easy to fix, but if it's the compressor itself, you would need to buy a new one.
pdq is online now   Reply With Quote
