Sure it is a blown engine or blown transaxle? Driving around in lower gear than usually (high RPMs) generally be harder on the transaxle than the engine, especially with an automatic. With a standard - possible that you could harm the engine.
Short answer - yes, the newer 9th gen Corolla 1ZZ-FE engines will "fit" in the 8th gen Corollas. Being a direct swap is a different matter. This has been discussed at length on the forum, just do a quick search.
