two different tire sizes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2011, 07:10 PM   #1 (permalink)
View xentris02's Photo Gallery
basicaly i was wanting to know if having a pair of 175 65 14 and another pair of 185 65 14 would really affect any thing i personaly dont think so as i havent had problems yet. what do you say? also the a set would be on the front and another on the back not left to right as i know that messes with things.
xentris02 is offline   Reply With Quote
Old 06-27-2011, 08:08 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
Speedo is calibrated somewhere in between. Assuming you have no ABS you can run both no problems but like you know NOT 175 on one side and 185 on the other! 175 can tide you over until you can buy two 185 to make a proper set.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 06-27-2011, 09:26 PM   #3 (permalink)
i have no idea if i have abs or not but what if i did?
Old 06-29-2011, 07:56 PM   #4 (permalink)
Beware of pigs
Buurin's Avatar
Pop the hood and look at your brake booster/master cylinder. That assembly with ABS is much bulkier because the ABS actuator and controller are right underneath it.
ABS also has a wheel speed sensor at each wheel. With tires of different sizes they will sense different speeds at each wheel. I don't know what would happen.
Buy my parts
Buy my other stuff
Old 06-29-2011, 09:40 PM   #5 (permalink)
on full afterburner
Gameroom cash: $1346497
Difference is minimal, but if you have to do it put the wider tires on the front.
Some people reverse stagger the tires on their fwd cars to help the car rotate more easily, but with those sizes I doubt you'll notice anything really.
Old 06-29-2011, 11:16 PM   #6 (permalink)
ok thanks
Old 07-07-2011, 09:56 AM   #7 (permalink)
i didnt see a need to start a new thread so i just wanted to ask would the 185's fit on the stock steelies of the ve i know the 185's were normal for the le and normal for the ve was 185? please let me know thank you
Old 07-07-2011, 10:20 AM   #8 (permalink)
pdq
Gameroom cash: $221400
View pdq's Photo Gallery
Yes, that would fit fine. 185 only came stock on the LE model.
pdq is online now   Reply With Quote
