5spd swap 2001 prizm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2011, 01:19 AM   #1 (permalink)
View TRDprizmcorolla91's Photo Gallery
ok...so i have a 01 prizm...i want to get rid of the stupid 4 spd auto and get a 5spd manual....i found the tranny but if you guys have any other info that would be great....i know id need a tcm but i can get my hands on one of those...anything else i might need??
TRDprizmcorolla91 is offline   Reply With Quote
Old 07-06-2011, 01:40 AM   #2 (permalink)
View expertmax's Photo Gallery
You will need :
New pedal set (Brake + Clutch)
Clutch Master Cylinder (Slave + Lines)
Floor mounted shifter (Your A/T shifter hole might be too big)
Shifter linkage
Flywheel
Patience and time
You might have issues with :
The Vehicle Speed Sensor which sends signals to the ECU might send wrong signals. (You will need to change the cluster or the ECU).
Transmission mounts
Clutch Start Switch harness (ECU capable?)
Will the axle fit ?
Will the starter fit ?
You will probably need to change the ECU (from a 5-speed).
Need help? Schematics? Ask and good luck with your project !
expertmax is offline   Reply With Quote
Old 07-06-2011, 01:56 AM   #3 (permalink)
all help is useful.....scematics would be nice..anything anyone thinks could help...im doing my research first so i can do it all in one shot so im not without car for too long
Old 07-06-2011, 03:24 AM   #4 (permalink)
You will need a friend to help lift the transmission. You should check if the parts prices will fit your budget and look for the best deal.
Old 07-06-2011, 08:45 AM   #5 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
Originally Posted by expertmax View Post
You will need :
Transmission mounts
Will the axle fit ?
Shifter hole is fine. Replace the bezel with the shifter boot and base from a manual.
VSS is the same.
Driver side and rear mounts need to change.
Axle will fit.
Starter will fit.
Need 5-speed ECU AND engine wire harness.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 07-06-2011, 11:01 AM   #6 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
Why would you need a new brake pedal (like the whole brake assembly?)I thought you only need the clutch pedal assembly?
ilovecorollale is offline   Reply With Quote
Old 07-06-2011, 01:32 PM   #7 (permalink)
Beware of pigs
Buurin's Avatar
Brake pedal on a MT car is smaller. After installing the clutch pedal an AT brake pedal will be dangerously close to it, if not interfering with it outright. Just look at all the tuner pedal pads they sell at a shop.
Buy my parts
Buy my other stuff
Old 07-06-2011, 06:09 PM   #8 (permalink)
burrin how hard is it to change the mounts???
Old 07-06-2011, 06:21 PM   #9 (permalink)
Beware of pigs
Buurin's Avatar
With the tranny out, not hard. It's the brackets that need swapping and you want to bolt on first. Subframe needs to come out so get an engine support beam. I have been able to reuse the front and side trans mount, rear one you probably can too but I swapped mine for good measure.
Buy my parts
Buy my other stuff
