Advice on Shocks&Struts and Brake Rotors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2011, 03:33 PM   #1 (permalink)
View bluesharks117's Photo Gallery
So I need to get my struts replaced. I was thinking of going with KYB shocks and struts. I want your guys' suggestions or tips. What do you think might be ideal for my '01 Corolla CE. I also need new brake rotors. Will performance brake rotors do a great deal and if so which brand/brands should i look into? Or should I just stick to stock?
bluesharks117 is offline   Reply With Quote
Old 07-08-2011, 05:13 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Depends on how you want the car to ride / handle - how you want the car to react when stopping, if you need more stopping power.
As for the struts - the can originally came equipped with KYB struts. Replacing them with KYB GR-2/Excel-G struts will be almost an identical replacement. If you wanted to stiffen up the ride a bit, enhance some of the handling - then this would be the ideal time to replace both the strut and springs. Something like Eibach and H&R performance springs will lower the car ride height slightly (1.25"-1.5") coupled with a strut like a Tokico Blue or similar, will greatly change the way the car handles.
For brakes - replacing the OEM rotors with performance ones, depends on the rotor in question. There are a number of OEM sized rotors that are cryo-treated, slotted, drilled, dimpled, specially vented, or some combination of those. Results can be mixed - depends on how and where you drive. Myself - replaced the OEM rotors with Brembo blanks (plain, vented rotors) - which also happen to be the Toyota OEM manufacturer. Coupled that with a performance brake pad - now you'll see some braking differences. For most cases, changing to a performance brake pad has a greater effect than replacing it with a performance rotor. Unless that rotor is oversized (ie, BBK - big brake kits, or caliper extenders (good and bad here) ) - you wont see much difference in most running conditions.
My car - 2002 Corolla
Suspension - running TRD springs (rebadged Eibach springs) and KYB-GR2 struts. Will be replacing those (GR-2 struts lasted 5 years! on the lowered spring) with some Tokico Blue struts. Suspension mods will have the biggest impact on the car - as it comes very softly sprung from the manufacturer. One of the best bang for your buck here.
Brakes - running Brembo blanks and Hawk HPS pads. Good for spirited driving on the street, though not recommended for track use. Rotor friendly compound, works well all year around. Couple this with a good tire and wheel package and suspension upgrade - completely transforms the car handling behavior.
If you want a good track/street pad - Hawk HP Plus is pretty popular. EBC Yellow Stuff has been reformulated - IMO, sits in between the HPS and HP Plus from Hawk, leaning more toward the HP Plus side. Akebono is OEM on Nissan, ceramic composite - low dust and noise, better bite than OEM organic pads, but not quite to the level of other ferro-composite pads out there.
The Following User Says Thank You to fishexpo101 For This Useful Post:
lr34x4 (07-15-2011)
Old 07-08-2011, 05:56 PM   #3 (permalink)
115k miles
01loadedLE's Avatar
Gameroom cash: $123100
View 01loadedLE's Photo Gallery
I concur with the Akebonos. I have them and I'm pleased overall with them but I want a little better performance so I'll be going with the stock rotors and Hawk HPS pads since their Plus pads would eat the rotors faster.
Fish would you know if the EBC's wear on rotors like the Plus pads do or if they are a little easier on them?
Sorry for the double post, this site is acting up on me.
I'd rather be flying.
Pics & info on my 01 LE
01loadedLE is offline   Reply With Quote
Old 07-11-2011, 04:54 PM   #4 (permalink)
[QUOTE=fishexpo101;3607258]
Do you have the part numbers for the rotors? And how much did those cost you?
Old 07-11-2011, 05:56 PM   #5 (permalink)
Gearhead
From what I've gathered from other owners - they are pretty gentle on rotors, at least the EBC Yellow Stuff pads. I haven't used them in some time, bad experience, but I've also heard that they revamped their compound - so I might give them another try here in the future.
[quote=bluesharks117;3609295]
I got them through Tirerack some time ago - part number is Brembo #25388 - "Front Ventilated Brake Rotors". At the time, I paid about $32 each + shipping - can't beat that price at all. Will be looking to pick up another set here, after these pads wear down. HPS pads are pretty rotor friendly, as long as you don't really overheat the pads. Once you do, they will be very aggressive on the rotor and eat it pretty quickly. You have to really try to overheat the brakes. With 5-7 hard stops from 75MPH+ to a dead stop, back up to speed and repeat, in quick succession is close to pushing the pads (DC Metro traffic ).
Next go around - might try out the Hawk HP Plus or the EBC Yellow Stuff with the plain Brembo rotors - depending if they are in stock anywhere.
