BRAKE light is on, do I need to flush/bleed my brake fluid and refill with new? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2011, 12:58 PM   #1 (permalink)
View photo_wed's Photo Gallery
Recently my 1999 Corolla BRAKE light on my dashboard come on when I'm driving / accelerating , then when I brake it goes away. But it comes back on sometimes and goes away. What is wrong with my brake?
The emergency brake handle is already released. When I looked at the brake fluid container under the hood it is at minimum, maybe a little bit below minimum so I'm guessing it needs more brake fluid.
So I went to Auto Advance and bought Valvoline DOT 3 and 4 Synthetic Brake Fluid.
My question is what are the steps I need to do to refill the brake fluid?
I googled and notice you have to flush or bleed the brake fluid? How do I do that? I don't have a front yard or garage and my car is parked in the streets so I can't do major auto repairs in the street. I can't just jack up the car and remove all the tires to bleed the brakes.
Is flushing or bleeding the brake fluid a lot of work?
Or should I just use a turkey baster or syringe to get some old brake fluid out of the brake fluid cylinder and pour in the new brake fluid?
Or should I just simply pour and max out the brake fluid without removing the old stuff?
photo_wed is offline   Reply With Quote
Old 07-10-2011, 03:07 PM   #2 (permalink)
View Kyle Hamelin's Photo Gallery
If you break fluid is below minimum it means two things. You have a leak be it slow or fast. Or you breaks are worn out (pads are two thin)
When was the last time you had new pads and rotors put on.
Kyle Hamelin is offline   Reply With Quote
Old 07-10-2011, 03:39 PM   #3 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
Low brake fluid and hand brake not completely released is just about the only circumstances that can trigger the brake light.
Flushing is a lot of work so just top it off unless you ran the brake reservoir dry. Then you need bleeding done and might as well flush it.
Wipe down the brake fluid tank rubber cap and pull it off. Top it up then put cap back on. Tighten brake fluid bottle tightly. Act quickly but carefully - brake fluid craves paint and water if left alone which is really bad, m'kay?
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
The Following User Says Thank You to Buurin For This Useful Post:
photo_wed (07-11-2011)
Old 07-11-2011, 06:06 PM   #4 (permalink)
View pchalpin's Photo Gallery
Check your front pads. Same thing happened in my 2000. Front pads were worn out. Fluid level was perfect, it was the pads.
pchalpin is offline   Reply With Quote
Old 07-11-2011, 11:31 PM   #5 (permalink)
Beware of pigs
Buurin's Avatar
Some pads has a sensor wire probably for this. Not on our Corollas though. Worn pads would just sink your fluid level which is easy to spot, either that or via a direct inspection of the pads.
Buy my parts
Buy my other stuff
Old 07-24-2011, 10:32 PM   #6 (permalink)
View Quick2000's Photo Gallery
add fluid, mine did the same thing under acceleration/deceleration or a hard turn. the sensor would go off in the reservoir as the fluid shifted.
Quick2000 is offline   Reply With Quote
