Engine Swap Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2011, 05:21 PM   #1 (permalink)
View mrmegnum's Photo Gallery
Engine Swap Issue
Had sludge like so many others. Car is an 01 Corolla with VVT. Swapped in an engine out of an 06 with a supposed 48k on it. Everything went fairly smoothly and everything bolted up nicely. Also used a starter off an 05, just to be sure. Now the engine will turn with the starter about 90 to 180 degrees then freeze. I can manually turn it past this point without much force and then try to start again and it will do the same thing. It seems like every time it gets compression it can't get itself past that point. Anyone else had an issue like this with any of their engine swaps? I can answer questions if more insight is needed.
Thanks
mrmegnum is offline   Reply With Quote
Old 07-16-2011, 05:32 PM   #2 (permalink)
View misterfix's Photo Gallery
sounds like the starter is weak or batter is weak. maybe bad ground wire or connection. check voltage on battery when it is cranking. does starter get hot?
misterfix is offline   Reply With Quote
Old 07-16-2011, 05:34 PM   #3 (permalink)
Could be timing is way off? to far advanced.
Old 07-16-2011, 07:04 PM   #4 (permalink)
Well the battery is on the trickle charger right now and I will try it again tomorrow. As for timing I would hope not. Wouldn't that cause issues with the valves actually jamming the rotation of the motor due to being off sync?
Old 07-16-2011, 11:37 PM   #5 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
This kind of swap has been covered here a few times before and it's now known that you can swap the long block, but need to keep some parts from the old engine (intake, throttle body). I assume this has been done?
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 07-17-2011, 01:27 AM   #6 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
Pull the plugs and turn the engine by hand, it should turn easy and feel smooth with no tight spots. Make sure you have a good/charged battery, then with the plugs pulled see if it will turn over. Should crank very easy and fast.This will tell you if you have any mechanical damage/ resistance. Put the plugs back in and crank it , if it still wont turn over , check your starter/ wiring.
sam333 is offline   Reply With Quote
Old 07-17-2011, 10:30 AM   #7 (permalink)
Yeah all parts that needed to be swapped have been.
I will try this out today. Battery should be charged and the starter is brand new so I'm going to assume that the starter itself shouldn't be an issue.
Old 07-17-2011, 10:56 AM   #8 (permalink)
randini667's Avatar
View randini667's Photo Gallery
Correct firing order?
randini667 is offline   Reply With Quote
Old 07-17-2011, 02:26 PM   #9 (permalink)
Beware of pigs
Buurin's Avatar
The engine computer should know the proper firing order. All OP needs to make sure is that the right plug goes into the right coil pack, which due to their location on the harness he can't really go wrong with.
Buy my parts
Buy my other stuff
Old 07-17-2011, 07:31 PM   #10 (permalink)
randini667's Avatar
gotcha. Was a thought
Old 07-18-2011, 11:59 PM   #11 (permalink)
00 rolla VE
View huangxin's Photo Gallery
What was wrong with your old starter? When I did my swap, I just reused the old started from my car.
[IMG]file:///C:/DOCUME%7E1/HP_Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
05 engine under a 00 hood! Another 8th gen is back on the road!
huangxin is offline   Reply With Quote
Old 07-19-2011, 08:10 AM   #12 (permalink)
Most likely nothing. Just did it to be sure all was working.
