Buurin,
Alright I think I've got you're explanation. Its not the horizontal rubber that runs across the top of door, right above the door panel itself. Its the rubber that runs vertical to the window. Do the runs go all the way to the bottom of the door itself? Thanks again, I certainly appreciate the advise. Also, do you have any insight on the rear drum brakes. The problem I have is the hole when I take out the plug is offset with the actual "star adjustment" and my brake spoon will not reach it. I have had it to Sears and a couple other places and they said the only way to adjust them is with the drum off, put on tight as possible then the self adjusters will do the rest. I don't believe that, because why is there a rubber plug to access the adjustment wheel or star. Do I need a special 90 degree brake spoon, has me baffled. I've always have done my own brakes, but have never seen the adjustment wheel not directly in front of the hole where you remove the rubber plug.Thank again
