Recharged A/C with redtek 12a - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2011, 10:38 AM   #1 (permalink)
View azncapcom's Photo Gallery
So i decided to recharge my a/c system with redtek. I put a can of proseal and 2 cans of 12a.
However, the results weren't great. i think my compressor may not be running properly? The a/c is cold when i give it gas (2k+ rpm) When its idling (800ish rpm) the air is barely cold at all...
Also i tried their oil analyzer and it seems like there is no oil left in the system at all? Would adding oil in the system help this situation at all?
azncapcom is offline   Reply With Quote
Old 07-21-2011, 07:24 PM   #2 (permalink)
View expertmax's Photo Gallery
Personally, I would take the car to a HVAC specialist to do a complete system flush and to put new coolant and oil in.
Corollas are known to have a very good air conditioning system !
2001 Toyota Corolla 5-M/T (1ZZ-FE)
1999 Toyota Tercel 5-M/T (5E-FE)
"What's the blood type of a Honda Civic driver ? Type-R" -expertmax
expertmax is offline   Reply With Quote
Old 07-21-2011, 07:37 PM   #3 (permalink)
That wouldn't solve the leak issue though. even after that bottle of proseal, it seems that the system has leaked again in only a matter of 3 days! i dont want to be shelling so much money to fix this a/c problem. with the amount of kms on my car, i can probably buy another one that has a working a/c for the same price as fixing my a/c?
i will see how much a good HVAC specialist will charge to diagnose the problem?
Old 07-22-2011, 10:54 PM   #4 (permalink)
Well you should try spraying soap with water on your lines, compressor and condenser. Also check your high pressure and low pressure valve, spray soap and water on them they might (unlikely) be leaking.
Old 07-23-2011, 10:58 AM   #5 (permalink)
I havent tried the soapy water method yet, but i did notice after recharging the system it was giving off a very bad odour everytime i turn on the a/c.
The charge only lasted about 3 days and its not blowing cold anymore again....
Old 07-24-2011, 12:46 PM   #6 (permalink)
Bdub215's Avatar
Gameroom cash: $317265
View Bdub215's Photo Gallery
May i ask why your using R-12? these cars required R-134.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 07-24-2011, 01:13 PM   #7 (permalink)
it is R12a, which works with r134. of course the old r134 has to be vacuumed first. Mines was completely empty already so i just filled it without vacuuming.
Old 07-25-2011, 07:20 AM   #8 (permalink)
View Ed G's Photo Gallery
You have to draw a vacuum before you refill the system.
And also install the correct anount by weight per the lable on the car
Ed G is offline   Reply With Quote
Old 07-26-2011, 08:23 AM   #9 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
R12: Dichlorodifluoromethane, CCl2F2
R134a: 1,1,1,2-Tetrafluoroethane, CH2FCF3
R12a: Claims to be proprietary, but mostly propane.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 07-26-2011, 08:32 AM   #10 (permalink)
[QUOTE Claims to be proprietary, but mostly propane.[/QUOTE]
How can it contain propane...........................
I know it would work great but a leak along with a spark
Old 07-26-2011, 07:46 PM   #11 (permalink)
Beware of pigs
Buurin's Avatar
[insert letter of the day]12a really is flammable and EPA does not approve.
Buy my parts
Buy my other stuff
Old 07-28-2011, 11:24 PM   #12 (permalink)
Always put R134a, period. The car has been designed to work with R134a. R12 was the best but R134a does a pretty good job.
