A/C Condensor Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2011, 04:20 PM   #1 (permalink)
View BigPip's Photo Gallery
Question A/C Condensor Removal
I have been searching with no luck to find out how to remove the Condensor in this car. I am assuming the bumper is coming off to remove it but wanted to be sure before getting ready to remove it.
Thanks for any insight-
BigPip is offline   Reply With Quote
Old 07-21-2011, 07:09 PM   #2 (permalink)
View expertmax's Photo Gallery
You have to remove the 2 radiator's top mount brackets, then pull the radiator up and tilt it (don't remove any hoses). Remove the in/out metal lines from the condenser (10mm bolt) and just pull on it.
Put your new condenser in and screw in your lines. Then make sure to properly pop back the radiator on it's supports and install the mounting brackets. Now go to a HVAC specialist to get new refrigerant and oil in. Don't use these DIY kits, they suck big time.
Good luck with your project, with temperatures rising to 105 degrees, it's important to stay cooled.
2001 Toyota Corolla 5-M/T (1ZZ-FE)
1999 Toyota Tercel 5-M/T (5E-FE)
"What's the blood type of a Honda Civic driver ? Type-R" -expertmax
expertmax is offline   Reply With Quote
