Originally Posted by debased
Also, my brother has a theory about a problem when the car changes from "open loop" operation to "closed loop" and that's why it runs fine if I restart the car.
The ECM will switch from closed loop to open look automatically as the engine warms up, provided it does warm up properly. A stuck open thermostat and resulting low coolant temperatures can cause the ECM to remain in closed loop mode longer or indefinitly. The O2 sensor signals are ignored by the ECM in closed loop, so your new O2 sensor sounds like it's probably OK if it runs good when restarted warm. The post-CAT O2 sensor monitors the catalyst efficiency only, so won't be the culprit here.
Have you checked spark plug condition (Iridium plugs don't all last 192,000 Km like the manual says), compression, air filter, fuel supply, and other basics?
