sub frame swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2011, 09:09 PM   #1 (permalink)
View fatfuzzy12's Photo Gallery
USA sub frame swap
i have a 2000 corolla that will need an eng and trans real soon. i was wonderinf if a complete subframe assy from a wrecked 2006 that was totaled from the rear would fit. thanks jim
fatfuzzy12 is offline   Reply With Quote
Old 07-29-2011, 01:20 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
This approach would be the one used when doing such swap on Camrys, but I doubt if
1) the gen 9 subframe is the same as gen 8, and
2) the subframe can withstand the weight of the powertrain when lifted into the car supported by jacks.
Best bet seems to be lift in/out the complete engine and trans through the top. Unbolt AC compressor from engine if you have it. A few parts need to be swapped over from the old engine - search for details.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
The Following User Says Thank You to Buurin For This Useful Post:
fatfuzzy12 (07-29-2011)
Old 07-29-2011, 08:40 PM   #3 (permalink)
thanks. was just thinking that having complete 06 setup in 00 would be good. probably will do the way you suggested. thanks again
Old 08-06-2011, 08:03 PM   #4 (permalink)
Bdub215's Avatar
Gameroom cash: $317265
View Bdub215's Photo Gallery
9th gens were a ground up redesign (although the motor was the same). the only way that idea would work is if you were doing a swap into a 7th gen where everything is basically the same.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
The Following User Says Thank You to Bdub215 For This Useful Post:
fatfuzzy12 (08-08-2011)
