At startup time (RPM up & Down) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2011, 06:30 AM   #1 (permalink)
View corolla1998's Photo Gallery
Wink At startup time (RPM up & Down)
This always happens at the startup time (when cold), the RPM will go up and down for a few minutes, until the car gets hot, then the RPM drops to a normal REV.
Would there be a senser that needs replacment, I recently purchased the vehicle and don't think this is normal.
thanks
corolla1998 is offline   Reply With Quote
Old 07-31-2011, 09:46 AM   #2 (permalink)
Bdub215's Avatar
Gameroom cash: $317265
View Bdub215's Photo Gallery
Possible intake manifold gasket.
Sent from my iPhone using Autoguide
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 07-31-2011, 10:00 AM   #3 (permalink)
is it a known problem with these cars, I would of thaught a worn out senser that connects to the trottle.
thanks for your help
Old 07-31-2011, 06:59 PM   #4 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
I also had this happen the first few days after swapping in a lightweight flywheel...
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 08-01-2011, 04:34 AM   #5 (permalink)
what was the solution, was it the gasket (intake) or the problem just went away.
thanks
Old 08-01-2011, 02:59 PM   #6 (permalink)
Beware of pigs
Buurin's Avatar
For me, it just went away...
Old 08-04-2011, 12:34 AM   #7 (permalink)
View expertmax's Photo Gallery
Try cleaning the Idle Air Control valve and replace the PCV valve, it's cheap and probably has not been done.
2001 Toyota Corolla 5-M/T (1ZZ-FE)
1999 Toyota Tercel 5-M/T (5E-FE)
"What's the blood type of a Honda Civic driver ? Type-R" -expertmax
expertmax is offline   Reply With Quote
