Another cluster swap question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2011, 01:15 AM   #1 (permalink)
View finkle1359's Photo Gallery
Hello everybody out there, sorry for beating a dead horse, but I'm not 100% how this is going to work. I have a 00 Corolla without tach, so I ordered one on ebay. When I ordered I mistakenly thought that 00-02 was the year range, not 01-02, so I ended up getting an 01 cluster non S. I saw on the FAQ that pin 2 and 3 need to be switched to make the 98-00 to work with 01-02 cars, will that work to make my 01 cluster work on my 00 car? I have no problem slicing into the harness, as long as I can fix the turn signal, high beam issue that seems to come up with the mis-matched clusters. Any help is greatly appreciated, thanks.
finkle1359 is offline   Reply With Quote
Old 08-01-2011, 03:02 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
No. It's switch 2 pins to make 00 cluster work in 01. I have done that. But not the other way around. Not only you need to switch wires, you also need to modify the circuit film on its back. You should find someone with a 01 and a 00 cluster and trade clusters (I helped broker one such trade before), or talk to your ebay seller.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 08-01-2011, 03:53 PM   #3 (permalink)
Thats what I was afraid of. Odd how the newer cars can work with the old cluster but not the other way around. Thanks, if anybody need an 01 cluster with tach, let me know.
Old 08-31-2011, 01:31 AM   #4 (permalink)
Gameroom cash: $196050
View landphil's Photo Gallery
Would you be interested in a straight across trade? I have a '99 cluster with tach I was going to put in my '01, still might, but could be interested in a trade as well. The speedo on mine is in kilometers, but you can re-use you old speedo to keep your odometer correct and the speedo in miles. PM me if interested.
"The thing about quotes on the Internet is you can't confirm their validity"
Abraham Lincoln
landphil is offline   Reply With Quote
