Sounds like the latch is jammed on you - the lock itself is probably unlocked, just everything that is supposed to retract the bolt to allow you to open the door is either loose or otherwise damaged.
The inside door handle stuck open is more troubling, means that the lock is completely jammed up, or the control link fell off / disconnected. Hopefully, on the handle side and not the lock side. If it fell off on the lock side, even pulling on the rod that runs to the door lock mechanism will not help, Slim-Jim tool would also not work in that case (if you try and grab the control link in the middle). Unless you are willing to sacrifice a door panel, your options are limited.
Could try lowering the window, make sure the door lock knob is pulled up (or unlock with the key), remove the inner door handle, grab the control rod with some vise-grips, and tug on the rod as you are wiggling and pulling/pushing on the door. Might free the latch enough to open up. If the If the latch is frozen or completely jammed, you are sunk at that point. Good Luck.
