Hi All,
It has been a while since my last post, a long while, but then again, the car runs well!
Firstly, do I have the correct generation for the car, as the title says, 98' geo prism? If so, I have a question about compatability of parts between Toyota and Chevy parts. ( did not see a FAQ about compatibility) Story;
Daughter hits parked car. Pass. side damages= breaks inner tie-rod, bends lower control arm, breaks axle.
I've purchased parts from Advanced, like their knowledge behind the counter. Ordered new axle, inner tie-rod, outer tie-rod,lower control arm & ball-joint.
Problem; Lower control does not fit. I ordered the Toyota arm because they do not carry the Prism part. ( I also ordered the Toyota ball joint to go with it. ) Toyota control arm is too short by about 1/4", from the rear bushing to the front b. Should I look for the Prism part or different year Toyota arm?
Also, will the toyota ball-joint fit the Prism hub?
Any help would be greatly appreciated! Thanks in advance!!
Scott
