2000 Corolla codes 0301 0170 0301 0170 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2011, 01:40 PM   #1 (permalink)
View kwill's Photo Gallery
Lean code and misfire code on cylinder no.1, I've replaced the coil pack on no.1, cleaned the EGR, replaced the MAF, new air filter, new plugs(weeks ago), swapped the coil packs around to see if the misfire followed but it stayed on cylinder no.1
I'm thinking about replacing the O2 sensors, any ideas?
kwill is offline   Reply With Quote
Old 08-10-2011, 05:25 PM   #2 (permalink)
pdq
Gameroom cash: $221400
View pdq's Photo Gallery
It could be an intake gasket leak. Do you hear any hissing sounds near the intake manifold? Check for any loose or broken vacuum hoses. Also, watch this video for a tutorial on using carb cleaner to check:
pdq is online now   Reply With Quote
Old 08-10-2011, 09:22 PM   #3 (permalink)
randini667's Avatar
View randini667's Photo Gallery
Swap fuel injectors 1 & 2, see if the misfire repeats on 1?
randini667 is offline   Reply With Quote
