hella horn - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2011, 02:11 PM   #1 (permalink)
mital917's Avatar
View mital917's Photo Gallery
hella horn
i was wondering if anyone has installed one of the hella horns on the 8th gen im thinking about it but dont know with wht set up i should go any info can help thanks
mital917 is offline   Reply With Quote
Old 08-15-2011, 07:16 AM   #2 (permalink)
Bennie's Avatar
Gameroom cash: $110951
View Bennie's Photo Gallery
The Hella horns are nice. Sound good, easy to install.
I've got the Hella's on one Prizm and a Stebel on the other. The Stebel was a pain to mount. Both seem to be about the same volume. I'd do the Hella's on both if I did it again.
'98 Prizm 4spd 272K bought @ 221K for $300
Oil consumption fixed @ 265K for $247
'99 Prizm 3spd 318K sold to brother 1/2012
Bennie is offline   Reply With Quote
Old 08-15-2011, 07:54 AM   #3 (permalink)
View papaxris's Photo Gallery
Just installed my Hella Supertones on my 99 Corolla over the weekend. I tested the factory OEM relay and fuse for voltage drop and total amps used by the new twin horns. You can utilize the factory relay and 10 amp fuse without a problem. I created a simple wiring harness to go from a single OEM horn to the twin horn setup.
I mounted one horn in the factory location and the other to the bolt on the hood latch.
Horns sound good compared to the weak denso unit. It seems that NOBODY would pay attention to you with the OEM horn. I can say this is not a problem anymore.
Let me know if you have any other questions.
papaxris is offline   Reply With Quote
Old 08-15-2011, 11:07 AM   #4 (permalink)
mital917's Avatar
i was just wondering if 1 hella horn would fine i dont want anything too loud just louder then the denso stock horn and would i need to change up the wiring if i just had one horn?
Old 08-16-2011, 07:07 AM   #5 (permalink)
Bennie's Avatar
They are to different tones so I would recomend both. I personally think it would sound a little funny with just one of the tones, however, if it doesn't bother you then go for it.
Old 08-16-2011, 09:04 AM   #6 (permalink)
mital917's Avatar
thanks everyone i had another quick question how much do they cost and is there a auto parts store where i can buy them rather then online?
Old 08-16-2011, 10:25 AM   #7 (permalink)
As mentioned by Bennie, they are dual tones, so you would need both to create the sound its intended to put out.
I have personally never seen them at the Auto Parts. I purchased mine from Amazon. Good luck with the setup. I'm sure you will appreciate it after you have switch over from the OEM weak horn.
Old 08-16-2011, 05:59 PM   #8 (permalink)
More Screens !
Gameroom cash: $210700
View kingnba6's Photo Gallery
if you guys want an air horn but dont want a complicated install then but the wolo bad boy. its an all in one so all you have to do is mount it in the stock horn mount. i use the badboy on my motorcycles. small and easy install
2004 Rav4 I4 FWD
Mileage-21004 as of 8/23/11
2009 Highlander V6 AWD
Milage-15xx as of 7/9/11
kingnba6 is offline   Reply With Quote
Old 08-17-2011, 08:56 AM   #9 (permalink)
Old Fart
Salty_Dog's Avatar
Gameroom cash: $195865
View Salty_Dog's Photo Gallery
I have the Wolo Bad Boy on mine too. If I was doing it all over, I'd get the Steibel but the Wolo is still definitely louder than stock.
Salty Dog
Visit www.TundraSolutions.com
The Web's best site for all information about your Toyota Tundra
Corolla: http://www.cardomain.com/ride/2933753
Tundra: http://www.cardomain.com/ride/2515030
Salty_Dog is offline   Reply With Quote
Old 08-17-2011, 09:02 AM   #10 (permalink)
More Screens !
i used to have the Stebel Nautilus the compact one. on my old 97 suzuki katana. i would of stuck with it but i got the wolo for cheap and quick so i went with it. anything is better then stock.
2004 Rav4 I4 FWD
