2003-2008 block into a 2000 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2011, 10:49 AM   #1 (permalink)
View ToyoDoc's Photo Gallery
anyone have any luck with putting a 2003-2008 1zz-fe block into a 2000(or like) corolla? i will be using the everything from my 2000.
ToyoDoc is offline   Reply With Quote
Old 08-18-2011, 01:47 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
That has been discussed before at length before, but you are correct, this is the preferred method for dealing with cases of excessive oil consuming 8th gen Corolla/Prism 1ZZ-FE engines.
The short block will work just fine (block, crank, pistons, con-rod - basically everything below the cylinder heads) - no problem. Since your engine is VVTi - using the 2003-2008 engine's cylinder head is also a non-issue. You will have to reuse your existing accessories, induction and exhaust systems - most cases, those are perfectly fine.
