How to disable the DRLs while keeping the automatic headlights on a '99 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2011, 04:12 AM   #1 (permalink)
View turbogalant's Photo Gallery
I kept finding people saying how you can't kill the DRL lights without killing the automatic headlights as well. It's actually really easy to do. Pull out the glove box, 2 x 6mm bolts on the bottom, and 3 x phillips head screws. Pull out that assembly; the DRL control module is mounted right under the passenger side airbag. There are 2 x red and yellow 18 gauge wires on one side of the harness, you can just cut them or just de-pin the harness like I did, there are two little tabs that will release the primary electrical pin lock, once that is off take something small, I used a small nail to release the secondary lock. You can pull on the other side of the wire with a pair of pliers, you really don't have much room to work with the harness wiring, but it's 100% do able. Take the two wires wrap them with tape or heat shrink like I did. Put back in the glove box and you're done. I can only verify that this will work for a 99 Corolla and Prizm, but see no reason that it should be that different for other years. If you're wondering, they use some weird ass version of a ground to drop the headlight voltage to 80% power, those 2 pins are the ones responsible for that. Since the automatic headlights are at 100% power they never see grounding from those pins, so that is still retained, as well as all other normal headlight function. Enjoy
turbogalant is offline   Reply With Quote
Old 08-22-2011, 02:38 PM   #2 (permalink)
View papaxris's Photo Gallery
Can you provide a schematic with the changes that you made? This modification is very appealing. Thanks in advance.
papaxris is offline   Reply With Quote
Old 09-18-2011, 12:46 PM   #3 (permalink)
View djgs's Photo Gallery
So basically wire those two wires together. Just wanted to make sure. For the moment I just disconnected pin 23 to disable both drl and auto lights. Thanks
djgs is offline   Reply With Quote
Old 10-15-2011, 12:53 AM   #4 (permalink)
No, you just take them out all together. If you're good with electronics you can pull the pins out, or just cut them if you want. They provide a ground for the "DRL" section, no ground, no light.
Old 10-15-2011, 12:57 AM   #5 (permalink)
I can post up a wiring diagram from the GM service manual if you want, but not too many people know how to read them. I also don't really want to pull apart the car again. But if you want to get me a picture of the module and harness I'll be glad to use it to show what I changed
Old 01-10-2012, 07:03 PM   #6 (permalink)
View corolla2002's Photo Gallery
Corolla 2002 DRL
O.K. folks. Everybody talks about cutting pin #21 from the relay. I have a 2002 Corolla. I looked behind the glove box under the airbag. My connector only has 12 pins. Can someone tell me where is this relay/modual. Is it black,silver,plastic. Or is it metal. Also turboG said There are 2 x red and yellow 18 gauge wires on one side of the harness, Are these red & yellow mixed on one wire. Thanks.
corolla2002 is offline   Reply With Quote
