engine tilt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2011, 01:03 PM   #1 (permalink)
View silversteed's Photo Gallery
engine tilt
I just put a junk yard motor in my sons can and it has a visible tilt to the rear. From under the car you can see the oil pan doesn't sit flat. It is much higher in the front of the car than the rear, but the front mount is all the way down and I don't think there is any adjustment in any of the other mounts.
How much tilt should there be and how would you correct this?
Any help is much appreciated and picture may be a big help.
silversteed is offline   Reply With Quote
Old 08-22-2011, 12:48 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Did you get the rear mount on correctly, that one is the hardest to get lined up. Did you have to take off any bottom support mounts before the engine got dropped in - ie, did you pull the old motor from the top or from the bottom?
