It's easier to get the OEM turn signal stalk with fog light switch. Drops right in. Also plug a relay into the orange spot on the junction block where the flasher relay is. On that block is another small, gray relay, get the part number off it and start hunting. With all parts on hand and an hour you have a clean, factory setup.
Buy my parts
Buy my other stuff
