For the past couple months I have been hearing groaning noises from Little Pig's rear brake when I'm about to come to a stop. Not when driving, does happen when pulling on handbrake without touching brake pedal, noise corresponds to wheel speed, so I'm pretty sure.
Today I jacked Little Pig's tail up and took the rear wheels off for a look. Both brakes seems to drag without handbrake set but that's a question for another day. I pulled the drums off, checked the drum and shoes and found both within spec, then cleaned the brakes well.
With the drums off I also pulled on the axle hubs on both sides. Nice and tight. No play.
I then retracted the automatic adjuster all the way on both sides. Drum back on and no more drag. Seems good.
Time for a road test.
Knowing I just did a brake job, I went slow. At the first stop sign my brake pedal just sunk to the floor and now I have much less brakes!
At least I can still downshift and I am not going fast. Am I glad I decided to do a road test first? F yeah!
So I pulled back in my garage, jacked up piggy's tail again and read the FSM. OK. I have to work the handbrake until I hear no more clicks from the adjusters. Did that. Did I heard clicks only from one side? Strange. Set the handbrake. Let me spin the wheels. LH side wheel is locked but I can spin RH side all I want! WTF? Off went the wheel and drum again and indeed - the adjuster is stuck fully retracted! Fixed that, put wheel back on and worked the handbrake again. Phew. at least it feels much better now, But the brakes drag again. Nah I'll ask about that here later.
Let's do another road test. Noise had not returned!
I just saved myself 100% of whatever $ this job would cost me. Should get myself some ice cream now.
