The engine should fit as long as the Matrix is not an AWD model. You will have to swap over your flexplate / flywheel, manifolds, some sensors, throttle body, injectors, wiring, etc. Your compression looks great, my service manual states that 189-145 is an acceptable range. Your oil pressure looks good, the service manual calls for a min of 4.3 psi at idle. Good luck! Getting a good used newer engine is definitely the way to go when solving an oil consumption issue.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
