1999 Toyota Corolla Rims heating up? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2011, 01:14 AM   #1 (permalink)
View Trinimd's Photo Gallery
I have a 1999 4 door LE
After driving for about 15 mins the steering wheel begins to shake and causes me to stop the vehicle. After a few minutes its fine again.
The Driver side rims get extremely hot!
These rims have been on the car for a few years
Any suggestions?
I am thinking something is going on with the caliper?
Trinimd is offline   Reply With Quote
Old 09-17-2011, 02:43 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
Spray water on the brake rotor. Does it sizzle? OK it should, you have to use the brake to stop the car don't you? But does it sizzle as much on the other side?
Either something is dragging or your brake rotor could be warped.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 09-18-2011, 08:45 AM   #3 (permalink)
View dannydanny's Photo Gallery
Any suggestions?
Drive the car until it shakes, then jack up that wheel and rotated by hand even push pull on the wheel check for bearing play. Good chance it might be the calipre.
dannydanny is offline   Reply With Quote
Old 09-19-2011, 11:26 AM   #4 (permalink)
ems
View ems's Photo Gallery
You more than likely have a bad brake caliper. Replace it and you should be fine.
ems is offline   Reply With Quote
Old 09-20-2011, 12:43 PM   #5 (permalink)
Replaced caliper works fine.
thanks
