Originally Posted by Debo954
Thank for the quick reply.
Just to confirm.
If the "speedometer" component is bad in my 1999 LE "cluster" (the whole unit) I can remove the "speedometer" part from the 01 and transplant it into my 1999 le cluster.
Correct.
Side note; the 2001 cluster had different connections in the back?
thanks again
The connectors are the same, but the 01-02 cluster is wired differently.
If you were to put a 01-02 cluster in an 98-00 Corolla the primary functions would work (speedometer, tachometer, fuel gauge, etc), however (from what I remember when I tried) your left blinker light will not work and your defrost button will instead turn solid on the left blinker light (I'm not sure if other critical warning lights would still work: ie oil, check engine, airbag, etc).
