Rebuilt head and 2001 corolla is using oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2011, 06:13 PM   #1 (permalink)
View rtassler's Photo Gallery
Any thoughts or input is appreciated. It doesn't smoke and is not leaking. I am using Castrol semi synthetic. 250 niles and almost 2 quarts of oil.
rtassler is offline   Reply With Quote
Old 09-27-2011, 09:12 AM   #2 (permalink)
View dorman68's Photo Gallery
I feel your pain, I have not had this issue directly but helped a couple of friends with this issue. The most common culprit for oil consumption in these engines is piston rings, they become gunked up and stick over time. The later 1zzfe engines have revised pistons and rings to remedy this issue. I have talked my friend into replacing his long block engine with an 05 or later model year. Hope this helps.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
The Following User Says Thank You to dorman68 For This Useful Post:
lr34x4 (10-14-2011)
Old 09-27-2011, 12:42 PM   #3 (permalink)
Bennie's Avatar
Gameroom cash: $110951
View Bennie's Photo Gallery
Was the head rebuilt to fix a pre-existing oil burning issue or did the problem start after you installed the rebuilt head?
'98 Prizm 4spd 272K bought @ 221K for $300
Oil consumption fixed @ 265K for $247
'99 Prizm 3spd 318K sold to brother 1/2012
Bennie is online now   Reply With Quote
Old 09-27-2011, 06:14 PM   #4 (permalink)
View Schubeedoobee's Photo Gallery
most likely oil leakage is the piston rings... if it was not using oil before, you may have an issue with the valve guides, and you may be getting seepage there.
Schubeedoobee is offline   Reply With Quote
