Corolla / Hotchkis Q - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2011, 06:35 PM   #1 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
Took my Corolla to the track and fishtailed and spun out on the first lap
I have the Hotchkis sway bar set with 3 holes on each end of the rear bar, for 3 levels of stiffness. The end links are bolted to the middle of 3 holes. I did not use the stiffest hole because I have read that struts may break. What could happen if I moved the links to the stiffest hole? Would it help with what I experienced?
On the front I also have the TRD strut bar.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
The Following User Says Thank You to Buurin For This Useful Post:
lr34x4 (10-14-2011)
Old 10-06-2011, 08:03 PM   #2 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
So you oversteered? You need to stiffen the front sway bar and/or soften the rear.
gold94corolla is offline   Reply With Quote
Old 10-07-2011, 07:35 AM   #3 (permalink)
Old Fart
Salty_Dog's Avatar
Gameroom cash: $195865
View Salty_Dog's Photo Gallery
I have the Hotchkis's on mine as well, and when I was driving home from the shop that installed them, the tendency to oversteer was the first thing I noticed.
Solution? Practice my driving so when I did a turn, I took the oversteer into consideration. Now that I'm used to it, I no longer have a problem.
Oversteer: You hit the wall with the rear of your car.
Understeer: You hit the wall with the front of your car.
Neutral steer: You hit the wall with both ends of the car.
Salty Dog
Visit www.TundraSolutions.com
The Web's best site for all information about your Toyota Tundra
Corolla: http://www.cardomain.com/ride/2933753
Tundra: http://www.cardomain.com/ride/2515030
Salty_Dog is offline   Reply With Quote
Old 10-07-2011, 09:14 AM   #4 (permalink)
on full afterburner
Gameroom cash: $1346997
Your tire choice will play a large role as well.
Old 10-07-2011, 09:25 AM   #5 (permalink)
as well as tire pressure, springs/suspension, weight distribution, etc.
Old 10-07-2011, 12:06 PM   #6 (permalink)
View Schubeedoobee's Photo Gallery
tire stagger, off throttle turn in, large rear/small front can all contribute.
it really depends on what part of the corner your spin initiated... give us a better description of the event.
Schubeedoobee is offline   Reply With Quote
Old 10-10-2011, 08:47 AM   #7 (permalink)
Beware of pigs
Buurin's Avatar
I have a ride video when this happened. Let me figure out how to cut/upload it (it's recorded in 1080p ) and I'll post it for your opinions.
Map of the track
Buy my parts
Buy my other stuff
Old 10-10-2011, 02:47 PM   #8 (permalink)
which corner?
love to see the video... I can probably make the claim that if you have not been out to the track much, you probably got caught out by the of throttle lift... on a FWD car it loads the rear end and induces over steer. on a FWD car if your over steering because of excessive speed/over rotation, you are suppose to give the car as much throttle on as possible. this is counter intuitive and has the effect of PULLING the car through the corner and out of the over steer situation.
diametrically if you give a RWD car throttle at over steer, you induce more rotation.
Here is one of me in an over steering FWD situation where cold tires(I had just come out of the pits) and to much corner speed caused me to lift which caused to much rotation... the correct thing to do would have been to mash the throttle, but I had already run out of road so thing only thing to do was to try and manage the spin and come out inline with the road...
Old 10-10-2011, 09:41 PM   #9 (permalink)
Young Buck
Press22's Avatar
View Press22's Photo Gallery
I'd like to see the video :P
Press22 is offline   Reply With Quote
Old 11-28-2011, 12:07 AM   #10 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
I know im a little behind, but Im running that setup and have been competing competitvely for years with it. If you want my alignment specs to dial in the car, pm me. the stock alignment with those bars will no doubt do that.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
