fuel pump noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2011, 12:36 PM   #1 (permalink)
View Quick2000's Photo Gallery
fuel pump noise
My fuel pump will start making a honking noise after driving about 30 minutes or so. I can make it stop if I tap the gas, but it will come back instantly. It seems to make the same noise if I'm at steady light throttle. It makes these noises in about 1 second intervals. Is it failing?
Quick2000 is offline   Reply With Quote
Old 10-08-2011, 12:59 AM   #2 (permalink)
jbod's Avatar
View jbod's Photo Gallery
you sure it's the fuel pump?
jbod is offline   Reply With Quote
Old 10-08-2011, 11:26 AM   #3 (permalink)
Pretty sure, the noise is coming from the rear driver's side wheel well. Any time I tap the gas and the injectors start pumping more, the noise stops.
Old 10-12-2011, 08:45 AM   #4 (permalink)
Bennie's Avatar
Gameroom cash: $110951
View Bennie's Photo Gallery
If it is actually the fuel pump making the noise then you lucked out and got a warning it's going out. Most of the time fuel pumps just crap out with no warning leaving you sitting on the side of the road.
I'd swap it out if I were you. It's super easy. There is an access cover under the back seat that has adhesive holding it on. Pull it off and you can get the pump right out of the tank.
'98 Prizm 4spd 272K bought @ 221K for $300
Oil consumption fixed @ 265K for $247
'99 Prizm 3spd 318K sold to brother 1/2012
Bennie is online now   Reply With Quote
Old 10-12-2011, 07:27 PM   #5 (permalink)
Bdub215's Avatar
Gameroom cash: $317265
View Bdub215's Photo Gallery
before you go and throw a fuel pump at your car, record a video for the class so we can hear what your hearing. I dont think its a fuel pump because A the pump is in the center of the car under the backseat making it near impossible to hear anything coming from it. B A load on the Fuel pump would cause more noise. now a engine noise transmitting through the car sounds better. But i'm just speculating.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 10-13-2011, 10:18 PM   #6 (permalink)
Well I can actually hear it clearly through both wheel wells in the rear. Wouldn't letting more fuel flow through the pump by pressing the gas strain it less since there's not such a pressure buildup?
Annoying sound huh?
Old 10-14-2011, 08:00 PM   #7 (permalink)
Bdub215's Avatar
Annoying sound huh?
surely is a odd sound. got yourself a timebomb in your trunk perhaps? after seeing that maybe the fuel Filter is clogged up. it is integral with the pump.
Old 10-15-2011, 05:53 PM   #8 (permalink)
My car just gets pissed off and honks at people haha. I'll replace the fuel filter and report my findings...
Old 10-16-2011, 11:18 AM   #9 (permalink)
View Bernie3's Photo Gallery
Your'e going to have to get under the car and look. It could be associated with the EVAP system. There are pneumatic valves attached to the vapor canister as well as a VSV for pressure sensor electrical valve. The VSV for pressure sensor is mounted to a small bracket that could be vibrating when the valve turns on and off.
Bernie3 is offline   Reply With Quote
Old 10-17-2011, 07:55 AM   #10 (permalink)
Hmmm interesting. I'll check it out later today.
Old 01-18-2012, 04:51 PM   #11 (permalink)
Well, I got the car on the lift and it seems like it is definitely the vsv right next to the canister.
Old 01-19-2012, 08:27 AM   #12 (permalink)
It's not the vsv...it's a circular solenoid or valve that sits right next to the canister. Is this the purge solenoid? Will I have to replace the whole canister?
